Buy Mark 8 Muscle products here.
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: engine code 172, 173
    Feb 2004
    Middleboro, Massachusetts, USA.
    151
    0
    Default engine code 172, 173
    Hey Guys,
    I have had an intermittant CE light on my '94, seems like when it is raining (or after I washed the car). It fluctuates on and off. I know there is a brick sized module in front of the radiator, I don't know what it is, but it does get wet. I scanned the computer and got two memory codes:
    #172 - Lack of heated oxygen sensor switches indicate lean bank 1
    #173 - Lack of heated oxygen sensor switches indicate rich bank 1
    Any ideas what the codes mean and if it could be related to the "brick" and it getting wet (maybe bad connection or something?)
    Thanks in advance.
    Jon
  2. #2
    Nov 2003
    Maplewood, MN.
    474
    0
    Default RE: engine code 172, 173
    My guess would be something is wrong with your oxygen sensor, which is in the exhaust. Perhaps it's burnt out, or there is a crack in the insulation so when the water contacts one, it is shorting.
  3. #3
    Mar 2003
    Omaha, NE, USA.
    321
    0
    I am getting these codes on my 94 now. Rich and Lean at the same time! Did you ever get yours fixed?
    David
  4. #4
    Feb 2004
    151
    0
    It happened a couple of times, but I haven't driven the car since the end of May...blown tranny, no time or cash to repair.:( I've got to get that taken care of pretty soon...
    amajamark8
  5. #5
    Apr 2004
    Pickering, ON, Canada.
    461
    0
    If I get both rich and lean codes from the same bank, it's almost always (except for a few bizarre cases) the O2 sensor. The "other" Frank is right. The outer shell is probably cracked and allowing water entry. Keep in mind, Bank 1 is the passenger side.
    Frankie X
    1995 Cranberry Continental
    1994 Black Mark VIII
    2005 Black Mercedes smartCar
    www.whiteoaklincoln.com
  6. #6
    Feb 2004
    151
    0
    Are they difficult to replace?
  7. #7
    Apr 2004
    461
    0
    They just thread into the exhaust like an oversized spark plug. That's not the point, though. Bank 1 is in a very awkward place-- you can't swing a normal wrench in that area. You need an O2 crowsfoot wrench, which can be found at any auto supply store, a 6-8" extension, a lot of WD40 and even more profanity.
    One thing you didn't mention in your first post: a really severe ignition miss in one or two cylinders on the same bank will cause both rich and lean codes on that single bank. How does your car run in the rain?
    Frankie X
  8. #8
    Feb 2004
    151
    0
    Like I said before, I haven't driven the car in a long while...I don't really remember. Probably not great, but the first time it threw that code was right after I washed it and I was thinking I got something wet.
  9. #9
    Mar 2003
    Omaha, NE, USA.
    321
    0
    They just thread into the exhaust like an oversized spark plug. That's not the point, though. Bank 1 is in a very awkward place-- you can't swing a normal wrench in that area. You need an O2 crowsfoot wrench, which can be found at any auto supply store, a 6-8" extension, a lot of WD40 and even more profanity.One thing you didn't mention in your first post: a really severe ignition miss in one or two cylinders on the same bank will cause both rich and lean codes on that single bank. How does your car run in the rain?
    It doesn't seem to matter - wet or dry.
    A severe ignition miss - so that could be a coil pack or wires or, what else??? plugs I guess... what else?
    94 Mark VIII, Black / Black
    dynoed at 247.5hp / 259.7ft-lb!
  10. #10
    Mar 2003
    Omaha, NE, USA.
    321
    0
    bump
