Buy Mark VIII, Supercoupe, and other Ford performance parts here.
Results 1 to 10 of 10
Thread: Compass Reset?
    Jun 2007
    Providence RI
    240
    Default Compass Reset?
    Hello,
    I have a 93 MKVIII, I noticed that when I replaced the factory radio the compass eventually stops working.
    Is there any way to get in back?
    Thank U.
  2. #2
    Jan 2007
    Wild and Wonderful
    11,387
    Do you have a subwoofer in the trunk?
    JP
    Boss 5.3L Modular Mark VIII
  3. #3
    Jun 2005
    Royal Oaks, CA
    9,805
    When you disconnect the battery, I believe you need to re-calibrate the compass. Look in your owners manual, it will tell you to drive in circles to get it to recognize North again.
    The infamous "Land Shark"
    Also Owned 97 Tan/Tan LSC
    Quote Originally Posted by driller View Post
    OK, I've been owned. Educate me.
    Quote Originally Posted by DLF View Post
    Was he just on vacation? Doubtful, but I suppose it's possible.
  4. #4
    Jun 2007
    Providence RI
    240
    Sub-Woofer = Why YES! I do! (^_^)
    Driving in circles... Yes, I did.
    Mind you that I replaced the OEM sterio with an after market. (what a sweet @$& unit)
    Lyfe Et Cetera
    [XXXXXXX][--------------------/
    Black 93 Mark VIII Stock w/185k miles Name: Nyghtshayd
  5. #5
    Jan 2007
    Wild and Wonderful
    11,387
    In the '93s the compass unit is in the rear shelf area and the magnetic field from a large subwoofer can cause issues with the compass.
    JP
  6. #6
    Jun 2007
    Providence RI
    240
    KHAAAAAAAAANNNNN!!!!!
    Oh well, no compass for me then. Unless someone has a solution.
    Lyfe Et Cetera
  7. #7
    Jan 2007
    Wild and Wonderful
    11,387
    You can try repositioning the subwoofer.
    In my '93 I have a simple closed single 12" sub enclosure. If I turn it around and/or position it in the trunk off center it causes no issue. Now if you have a dual 10" ported box like in my '96 - you're out of luck.
    JP
  8. #8
    Jun 2007
    Providence RI
    240
    Lyfe Et Cetera
  9. #9
    Jun 2007
    Providence RI
    240
    YES! I got it to work again!
    Factory Amp's gone so I didn't need the tray back there anyway.
    So I simply remounted the compass away from the vent holes of my Bass box.
    Vioulla! The compass returns.
    Thanks again you all.
    Lyfe Et Cetera
  10. #10
    Jan 2007
    Wild and Wonderful
    11,387
    Quote Originally Posted by Nyghtshayd View Post
    Kewl fix!
    JP
