Click here to join the club!
Results 1 to 6 of 6
Thread: 2003 Town Car Door Panel Removal....
    Jun 2005
    Royal Oaks, CA
    9,813
    0
    Default 2003 Town Car Door Panel Removal....
    Another post specifically for Glen.........see the arrows Glen? Ya, those black ones? Yep, those right there....lol.
    REMOVAL
    NOTE: LH side shown, RH side similar.
    Disconnect the battery ground cable.
    Remove the window switch plate.
    Disconnect the electrical connectors.
    Open the screw covers. CAUTION: Use care not to damage the trim panel covers.
    Remove the screws and the assist handle.
    Remove screws and the front door trim.
    The infamous "Land Shark"
    Also Owned 97 Tan/Tan LSC
    Quote Originally Posted by driller View Post
    OK, I've been owned. Educate me.
    Quote Originally Posted by DLF View Post
    Was he just on vacation? Doubtful, but I suppose it's possible.
  2. The Following User Says Thank You to J For This Useful Post:
    Hot*Mk8 (06-17-2015)
  3. #2
    Mar 2005
    Houston, Texas, New UNA
    1,651
    66
    Thanks JJ
    http://www.lincolnsofdistinction.org...ine=1203550468
    Mark VIII 94 Dark Portofino Blue/Portofino Blue
    14.3110@95.38
    2005 Cadillac CTS-V
  4. #3
    Aug 2009
    nevada
    3
    0
    Nice pictures .............................
  5. #4
    Oct 2009
    3
    0
    Nice information
    thanks dude......
  6. #5
    Oct 2011
    3
    0
    hi everyone i have a 2003 towncar this is a very nice help but my problem is there are pockets in my doors so where are the lower screws at? also how and where do you pray the pull strap covers at dont want to break or damage them thanks you very much
  7. #6
    Jun 2005
    Royal Oaks, CA
    9,813
    0
    Let me look to see about the pocket, if you do have a pocket I'd assumed there are no lower screws, instead you'd take everything else apart and get a "feel" for the panel to see if it's loose.
    As far as the strap covers, the arrows are pointing to the top and bottom on the picture above, my best advise is to use a flat head screwdriver (really small one) and put painters tape on the end of it to prevent scratching. Also push your finger against the door panel to make a gap behind the cover to put the screwdriver in.
