Buy Mark VIII, Supercoupe, and other Ford performance parts here.
Results 1 to 9 of 9
Thread: DIY AC Recharge Kit?
    Default DIY AC Recharge Kit?
    My AC doesn't seem to be a cool as it should be. What are your opinions on do it yourself AC recharge kits that can be purchased at auto parts stores? Are these effective/safe/easy to use?
    Thanks!
  2. #2
    Apr 2007
    Green Bay, WI
    1,063
    Well first you need to know one thing. AC systems should never become less effective, ever. Coolant does not get weaker, etc.
    So if its not up to par, there is a leak. Keep that in mind if you do one of these kits.
    Yes they work. I have used them in the past. In WI one can not buy the cans of R134a so I get them shipped up from Chicago. I replaced all the seals on mine but I found a leak caused by rust and will be doing this again.
    1996 Opal Opalescent with
    2004 Aviator Power Plant
  3. #3
    Mar 1999
    Weatherford Texas
    1,051
    Quote Originally Posted by Brent824 View Post
    Thanks!
    What does the "kit" include?
    1994 Mark VIII: HOTLNC
    2010 Fusion SEL 3.0L V6: LILLNC
    2011 Lincoln MKZ 3.5L V6: Jelly Roll
    1987 F-350 6.9L Diesel Banks Turbocharger. Truck Name: Bad, Bad Leroy Blue
  4. #4
    Feb 2004
    Lincoln, NE, Lancaster.
    1,076
    The better ones come with the required hose and gage, the proper adaptors and somme freon. Read the directions carefully - dont let "simple" cause you to trip, and dont over fill.
    http://www.adenracing.com/Pictures/1...iplashLSC2.jpg
    1995 LSC Black on Black aka Stealth
  5. #5
    Thanks for all the help!
  6. #6
    Mar 1999
    Weatherford Texas
    1,051
    Quote Originally Posted by whiplash15 View Post
    I've always wondered how one determines "overfill." The big boys do it by weight (filling empty systems.) But what about a partially filled system? Can you do it by pressure and temperature?
  7. #7
    Jan 2007
    Wild and Wonderful
    11,382
    Quote Originally Posted by HOTLNC View Post
    ...Can you do it by pressure and temperature?
    I'm sure you can. I know with the older systems, you could do it with just guages and temperature probe.
    JP
    Boss 5.3L Modular Mark VIII
  8. #8
    Oct 2007
    Kansas City, MO
    410
    Yes you can but I don't feel it is as accurate unless you are using a gauge set with a high side connection rather then the low side only connection found in the DIY kits.
    If you only have a low side gauge and are going by temp and pressure it should be around 55 to 65 pounds of pressure on the low side at idle was 70 degrees outside. This would correlate to around 40 to 50 degrees for the system temp. (of course all of this is without looking at an actual gauge). The compressor should be running almost non-stop at this point.
    But there are so many variables (engine speed, outside temp, freon charge) that's why I prefer to use the high side as well which will hover just over 300 psi when fully charged and operational.
    In addition to getting a proper charge by monitoring the high side you can also verify there is nothing else wrong with the system, such as a blocked orifice tube. Which if you were charging only on the low side you wouldn't be able to see until you blew the over pressure valve.
    "I'd rather push a Ford than drive anything else."
    Current Cars: -2008 Taurus X (84k) 1997 Lincoln Town Car (145k) - 1996 Mercury Cougar (260k)
    Previous Cars: 2003 Mazda 6 (160K) - 2002 Mercury Mountaineer (94k) - 1990 Mercury Cougar (168k)- 1977 Lincoln Town Car (141k) - 1996 Lincoln Mark VIII (116K) - 1997 Lincoln Continental (203k)
  9. #9
    Oct 2007
    Kansas City, MO
    410
    Thanks!
    To answer the original question, they can be if used properly. As others on this forum have said, A/C's don't just stop working because of age. When was the last time you added freon to your fridge just because?
    There is something wrong with the system or freon has leaked out. So fix the leak first. :-)
