Click here to join the club!
Page 6 of 9 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 90
Thread: FS: Mark VIII IRS Sub-Frame Bushing Kits
  1. #51
    Jan 2009
    New Jersey
    2,933
    11
    5 sets of upper bushings done! Now I have to make the lower bushings. Still waiting for the sleeves to come back from being anodized.
    Attached Images Attached Images
    98 Toreador Red Mark VIII LSC - 13.217 @ 104.78
    98 Laser Red/Black Cobra Coupe (T-56/IRS) - 12.483 @ 110.94
  2. #52
    Jan 2009
    New Jersey
    2,933
    11
    Default Look at what showed up today!
    The sleeves arrived today!
  3. #53
    Jan 2009
    New Jersey
    2,933
    11
    Default Removal Instructions
    JP, I'm going to ship your set Monday, along with the removal tool, for a test fit. I'll need the removal tool back as soon as possible.
    To remove the stock bushings:
    1. Remove the top hat.
    2. Position the U shaped piece under the bushing to be removed.
    3. Insert the threaded rod with nuts and washers and tighten the nuts (11/16") to remove. The bushing will just fall gently out of the bottom after a bit.
  4. #54
    Jan 2009
    New Jersey
    2,933
    11
    Default Installation Instructions
    To install the new UHMW bushings:
    1. Clean the sub-frame bushing mount holes.
    2. Insert the upper bushing. You'll may need a dead blow hammer, it's an interference fit.
    3. Tap in the sleeve from above, to just below the top surface of the upper bushing.
    4. Place the 1 1/2" stainless steel washer on top of the sleeve.
    5. Press the lower bushing up from below until it stops. There should be a very small gap (see picture) between the top of the lower bushing and the sub-frame, that will disappear when the bolt is tightened.
    6. Insert all 8 bolts loosely, using the stock sub-frame bracket (front) and cup (rear). 4 - sub-frame, 4 sub-frame brackets
    7. Align the sub-frame using the alignment holes on each side near the back of the sub-frame. (I'll post some pictures of this when I re-install mine in a couple of days)
    8. Tighten bolts as indicated.
  5. #55
    Jan 2007
    Wild and Wonderful
    14,589
    1,142
    Thanks Doug.
    I presume test fitting these in the spare IRS I have will tell us what we're looking for?
    I'll get on it as soon as I can once I receive the parts and tool, but it may be the weekend before I can get time from work to do this hobby thing. I'll even take pics. But I'll get the tool back to you as quick as I can.
  6. #56
    Jan 2009
    New Jersey
    2,933
    11
    Quote Originally Posted by driller View Post
    Thanks Doug.
    The only thing I need to know is if the gaps between the upper edges of the lower bushings are like the last pic I posted. I'm looking for something around 1/16".
    In my sub-frame the two rear tapered holes are slightly (.050") smaller than the front two holes. I need to know if that's consistent in other sub-frames.
    When I send your kit, the four upper bushings will be the same, but there will be two lowers tagged front and two lowers tagged rear.
    You should receive everything Wednesday.
    Weather permitting, I'll be track testing mine on the 10th.
  7. #57
    Jan 2007
    Wild and Wonderful
    14,589
    1,142
    Quote Originally Posted by DLF View Post
    Aye, Captain! We'll report back the results.
  8. #58
    Jan 2009
    New Jersey
    2,933
    11
    Here's what you get in a full set.
  9. #59
    Jan 2009
    New Jersey
    2,933
    11
    I got another IRS sub-frame today, and confirmed that the measurements from my sub-frame are consistent.
    I've also shipped one set out to Driller for a test fit.
    Pending Driller's test fit, I should be ready to ship the kits that have been paid for by the end of next week.
  10. #60
    Jan 2009
    New Jersey
    2,933
    11
    Sub-Frame alignment and installed pics.
    On the left rear is a tab on the sub-frame that corresponds to a hole in the uni-body that is used to align the sub-frame during installation. Use a 3/4" pipe (or something similar, I made my own tool), and make sure that the pipe is vertical. Tighten the left rear mount and then go to the right rear of the sub-frame and use the alignment holes located there to complete the alignment. Then torque all four bolts.
