Buy Mark 8 Muscle products here.
Results 1 to 5 of 5
Thread: Leaking from schrader valve?
    Jan 2010
    137
    0
    Default Leaking from schrader valve?
    I popped my hood to verify that in the morning there is 0 fuel pressure, when i notice a very very slight noise. I put my ear over the schrader valve and while it is completely empty of fuel, i can hear a noise coming from it, a leaking sound. I pressurize the rail and the noise stops. My fuel pressure is leaking over an hour or 2, checked injectors, and also have 32psi instead of 35. Without vacuum i will have to double check, i have a large fuel pump in there already though. I have been running out of fuel at the top and i really dont think the pump is bad, its MAYBE 6 months old and 255 lph.
    I called advance and they told me the schrader valve replacement is dealer only, so i'm looking for a part number or where to get it? I'm sure they have one, they just dont have the brightest people working there. Or owning it for that matter lol.
  2. #2
    Feb 2009
    Near Chicago
    649
    0
    Is the rail completely empty of fuel? Or do you have pressure?
    1997 Lincoln Mark VIII LSC
    Toreador Red
    142,000m
  3. #3
    Apr 2010
    Lutz, FL
    825
    1
    It is possible that the schrader valve is venting some air pressure, but not fuel. When you pressurize the rail, the valve seals up.
    Andrew
    96 MKVIII Base
  4. #4
    Mar 2003
    Millersville, Maryland, USA.
    8,160
    44
    ....or it's supposed to......
    Bud Pytko
    2015 Lincoln MKZ Hybrid
    2005 Ford F250 6.0 PSD CC 4X4 LB
    2007 Arctic Fox 30' 5th Wheel
  5. #5
    Oct 2003
    Port Clinton, Ohio, USA.
    2,993
    187
    You did change your fuel filter when you changed your pump?
    "The Whinery"
    535 RWHP
    486 RWTQ
Similar Threads
  1. Leaking problem!!
    By charlotte in forum Mark VII
    Last Post: 12-12-2007, 12:44 AM
  2. I have air leaking - Where do I start?
    By 4sracn in forum Brakes / Suspension / Steering
    Last Post: 11-26-2007, 12:09 PM
  3. Air line leaking?
    By mja400ex in forum Brakes / Suspension / Steering
    Last Post: 04-23-2006, 10:43 PM
  4. Leaking tires
    By joemark8 in forum Tires and Wheels
    Last Post: 01-02-2004, 01:57 PM
  5. Well, something is leaking
    By jbuch in forum Drivetrain
    Last Post: 04-17-2003, 08:50 PM
